주요 콘텐츠로 건너뛰기
Released in November 2012, the GoPro HERO3 is a Wi-Fi capable, 4K resolution digital camcorder.
104 질문 전체 보기
My GoPro got wet
Hi. I was surfing and after a wipeout my GoPro case got broken and consequently my GoPro Hero 3 got wet (salt water).
I tried to let it dry but after this incident, the camera doesn't turn on anymore and now only blink a red light on the back of the camera.
Nothing else happens.
When I let it charging for around 30 minutes, the GoPro display shows "GoPro" but nothing else happens.
Do you guys think that could it be a solution for that? I really don't know if it is, but.. well.. let's try to ask ;)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I'm experiencing the same issue. But, I did NOT wipe out and I have been incredibly careful with the housing and camera. The is the second GoPro to have issues. I think it's time to give up!!
댓글 달기
답변 1개
선택된 답변
Hi,
So the bad news is salt water is electronics' worst enemy. With that being said, the device still shows sign of life which is good. What you can do is follow the ifixit teardown guide to take out the logic board. After you take it out put it in something that has greater than 70% alcohol and scrub it with a toothbrush. dry it with a hair dryer or just leaving it out to dry for a few hours and try to reassemble it. If the water damage was minor, it should work.
GoPro Hero3 Teardown
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thank you so much I don’t know what I would have done without this
댓글 달기
귀하의 답변을 추가하세요
ra7osurf 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 5
전체 시간: 1,277
