주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung NaviBot SR8855는 삼성에서 만든 편리한 자율 주행 로봇 진공 청소기입니다.
Short shift and turn.
Navibot sr8855 after repair of FET tranzistors for brush have bad mooving - navigation.
From the beginning it worked well and after some time was problem in navigation.
It looks like that: move 20-30cm stop and go back about 3cm, turn 90st. and repeat.
Sometimes work good for 1 minute and then again fail to this state.
I try test mod and all sensors look fine, motors are OK too.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 1개:
I have the same issue. Is there a fix?
의
댓글 달기
답변 5개
Hi,
yes, i found that it was dusturbation in system . I add some capacitors on motor and all is OK
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Can you describe more precise what did you done?
Could be the aging of the accumulator?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I must replace suction motor and with it start the disturbance of electronics. For this I used capacitors on motor pads. I was 1nF + 100nF + 1uF together. To other motors must be carefull becouse are PWM drivered. There You can use only some smaller - max 100nF capacitors.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi
What voltage do you use in capacitors?
의
댓글 달기
Can be that the battery started to decay?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It could probably have an effect but it is not a reason.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
smsoftware 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 23
전체 시간: 2,310
