주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Mic and Home Button do not work after screen replacement
I changed my iPhone 5s screen and the battery. When turned on the phone and I test that the phone works right, I realized that the mic and the home button didn't work. What should i do? Thank you
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 3개
가장 유용한 답변
Hi David,
Since both the microphone and home button are not working, this would point me to believe that the charge dock connector came loose will the phone was being worked on. Microphone and home button both run through the charge dock flex. Open the phone back up and check to see if the connector directly above the battery connector is plugged in or not, try to reseat the connector. If it is plugged in correctly and is still not working, then it may need a new charge dock flex and/or a home button cable. Hope this helps.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
I've tried with 3 dock flex and it do not work. That is why i don't know what's the problem
댓글 달기
i have the same problem. i tried putting the mainboard in a new phone. same problems. its something on the mainboard... i hope i get it fixed today.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
then , did you fix it ?
댓글 달기
The Mic & Home Button connector are both part of the dock connector flex. Trying unplugging the dock connector flex (located right above the battery connector) and plug it back it. If that doesn't fix the problem you may need a new dock connector flex cable.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I've tried with 3 new dock flex and it still do not work
댓글 달기
귀하의 답변을 추가하세요
davidmavi16 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 5
전체 시간: 355
