주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
Does iPhone 6+ LCD is replaceable?
Hello everyone.
Just little question, i've seen many peoples talking about changing the LCD of iPhone 6+ will make the home button stop working, and device will not open after for the error.
So, as you can see here, iPhone 6 Plus LCD 및 디지타이저 교체
At the step 32, we have to peel the button flex (highlighted in red in the second picture), so does this "button flex" on the LCD are sticked to the LCD or sticked to the metal LCD shield ?
And does we can repair iPhone 6 Plus LCD without changing the original button, and make it work like a new, including touch id function?
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 3
댓글 달기
답변 2개
선택된 답변
If you keep the original home button and put that on your new screen, you will be fine, changing the home button will cause error 53. :-)
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Yes i know for that, like the 5S...
But, i don't really understand what to do at the step 32, "we have to peel the button flex (highlighted in red in the second picture), so does this "button flex" on the LCD are sticked to the LCD or sticked to the metal LCD shield ?"
Thank ?
댓글 달기
in that step, you are releasing the connector from the adhesive that holds it to the screen. Once it is free from the screen, it is still attached to the metal plate, but you just remove the metal plate and flex together, as they come out as one piece (see pic)
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Amazing, thank to you!
댓글 달기
귀하의 답변을 추가하세요
Phonetech93 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 530
