주요 콘텐츠로 건너뛰기
13인치 디스플레이가 장착된 MacBook Pro 모델에 대한 수리 정보 및 가이드.
9741 질문 전체 보기
질문 마감됨
New logic board, dim charger light and won't power on
I replaced my logic board after water got spilled on it and the other one fried. After installing the new logic board it started up fine and even charged. I left the MacBook on the table over night not connected to the charger. When I went to use it today it would not turn on and the power adapter had a dim green light.
Do I need to replace the DC MagSafe in-board or is there something else I should try before this?
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
I bought from macpalace and they have a pretty horrible return policy for logic boards so I hope I don't get hosed on this purchase because I will be !#^&@@.
Hey Muscle have you carefully checked all your connections
If they are an @%^$$@$ about it just file an charge back. the reason why most places give you a hard time in returning things is because they are selling crap.
댓글 달기
답변 2개
선택된 답변
you have a smc issue. it sound like the "new" logicboard you got is defective.
return it and get it from a different supplier.
해당 답변은 도움이 되었습니까?
점수 0
댓글 6개:
How did you come up with it being an SMC issue? Is there no other fix then to get a new one?
the SMC of your computer is what tells the charger to let the power in. something is wrong with your smc to one wire line to cause this. if you just brought a new logicboard then there is no reason for you to waste time to fix it just because they sent you a defective item.
Hi John, magsafe doesnt have a right direction to plug in. it is build with a symmetrical magnet design. Also when a magsafe is disconnected the light goes out instantly. when the charger light dims that mean something on the "one wire circuit" is shorted to ground.
Your absolutely wrong And your telling him to give up on it . I quickly hooked a1278 to run ASD last week in the middle it shut off the light went dim I went back and fasten tight -complete.
you are a joke, ASD test nothing but temperature gauge.
댓글 1개 더보기
댓글 달기
가장 유용한 답변
Yeah there is something you can try go back and make shure it's all tight the magsafe plug is very easy to come loose when set back in upside down. And FYI it's not always the one wire I've accidently let the plug slip to get the faint green light. You need to exhaust the easy before the hard.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 254
