주요 콘텐츠로 건너뛰기
MacBook Pro 15" display 모델
8255 질문 전체 보기
질문 마감됨
new battery won't charge
MacBook Pro 15" Core Duo Model A1286
My original battery was swollen, so I bought a replacement. It worked fine for 3 months.; then suddenly stopped charging. Computer wouldn't work at all until I removed the battery. I bought another battery. It began charging, but after 2 days it stopped. The charging light blinked green. Again, the only way the computer worked was by removing the battery.
My tech suggesting getting a battery from ifixit, as you guys are reliable. I did. It began charging. Battery indicator showed it would take over 7 hours to charge. At about 15% it suddenly stopped charging, and once again, the charging light indicator flashes green. Couldn't start up computer until I removed the battery.
So the problem is clearly not the battery, but I have no idea what it is! Can you help me troubleshoot this?
Update (10/07/2015)
I just clicked on your suggested item and bought it. I'm afraid I didn't check for compatibility, and the connector is for a different laptop. Mine is early 2011, and has an installed battery.
1. Do you know if I can get it exchanged?
2. Can you suggest anything else - is there a battery connector I can buy? (I think it's a A1286)
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
I was advised to replace the MagSafe DC-In Board, which I did. It didn't help. Charging light blinks green, and computer won't work until I remove the battery. Can anyone suggest anything else to try?
댓글 달기
답변 1개
선택된 답변
I have seen the battery connector board fail and It's about your last shot: MacBook Pro 15" Core Duo Model A1150 Battery Connector Replacement
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Thank you. I will try it and let you know.
My laptop is an A1286. I don't see any similar part available to replace. Any suggestions before I give up and treat my laptop as a non portable computer? : (
댓글 달기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 271
