On the PS4 Pro, the disk drive is on the front left side of the console. When I put the disk in, as soon as I hear it's in and stopped inserting, I would "hit" not "tap" that top left corner. I was surprised at how hard I had to hit it. When the drive tries to read the disk, you can hear it trying to spin and find the spot it needs. When you hear that attempt again, you can try and hit it again. Sometimes it would work on the first attempt, sometimes on the 2nd, 3rd, 4th etc. I remember it trying around 4 or 5 times, then pause, then another 4 or 5 times, before it would give you a disk reading error. Sometimes I'd have to eject the disk, and just go through all that again.
It's beyond ridiculous that this even has to be done. I finally gave up on having to do this, and purchased the online version of the game I play 95% of the time, After spending $160 back in Dec to Sony to fix/replace the drive, it started again literally 2 weeks after the 90-day warranty on the original repair, expired. They refused to help me out. They couldn't tell me exactly what they did the first time (either fix or replaced the drive3?). I had it set up to send it in again, but then cancelled it. To !&&* with them.
댓글 69개
I'm having the exact same problems I tryed a DVD it worked then a couple of try's later a PS4 game worked check it reads DVD if so it thinks the bluray ain't an original and can't support it..I'm going to try unplugging for 24 hours then il update again...
johnbhoy11 의
I tried the method I saw on you tube but soon realized that I had a 1200 series unlike the one in the video mine had 2 screws and a different disc drive completely. Is there a way to fix the 1215A model?
Tramaine Wilson 의
Nvm. Fixed it like the day after I posted. Was pretty simple. Works perfect now.
Tramaine Wilson 의
What was your problem I'm having the same
johnny.jones414 의
I'm trying to play GTA 5 its installing only 30% then says unable to read disc . I went a month with out playing my game but it still doesn't work right now it's on 14% later on it's going to say disc not recognize happens with all my other games GTA , call of duty black ops3 , and uncharted 4
Malik Humphries 의
댓글 64개 더보기
