주요 콘텐츠로 건너뛰기
Support for tablets by Coby, including the Kyros line.
65 질문 전체 보기
Where can I find a replacement battery?
My daughter's tablet, a Coby MID-7036 will not power on and not charge. I have it taken apart and see the battery connector is soldered onto the motherboard. I can de-solder it or snip and strip the wires to connect a new battery but I can't find a replacement battery anywhere. Any ideas where else I can look or is there a way to use a battery with similar dimensions and capacity?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 5
댓글 달기
답변 1개
가장 유용한 답변
I was able to search the s/n on the battery case itself and found a replacement on Ebay. I sniped the wires off the old battery and soldered the ends to the new battery and used heat shrink tubing to cover everything up. Device charged up and is good to use.
해당 답변은 도움이 되었습니까?
점수 2
댓글 2개:
Hi Brian
I thank you for the advise.
How much was the battery and how Long did you wait to receive the battery
Thanks
댓글 달기
귀하의 답변을 추가하세요
PolishRifle 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 3
전체 시간: 1,057
