iOS X: Error Code 47; Windows: Error Code -1
Hello Everybody,
I run into a problem today. I had to change my Screen (LCD, Digitizer..) because it didn't work, maybe because of some water damage.
After replacing the screen the phone worked again. And to mention: Before I changed the screen I was able to start up the iPhone, I knew that because it vibrated when I switched the mute button. Just to state: It was able to restart.
So I started up the iPhone with the new Screen and made some stuff etc. and decided to update it (since it was jailbroken and I wanted the new iOS). So after pluggin in my Device it did everything with restoring etc. the restore (update) loading bar on the iPhone was 3/4 full and then it stopped with the error code 47 on Mac OS X and Error Code -1 when I tried to restore/update it on a windows. Since then im stuck in the dfu mode.
What I did:
Updated itunes on both win/os x
Reinstalled itunes on win /no can do in OS X
changed lightning cables
set my iPhone into DFU mode manually (or again) /since im stuck in that
I removed the exchanged screen again to check if I maybe made a default by clipping some clips but it was everything ok
So my question is: How can I update/restore my iPhone? I know it worked properly since I could restart it and use it normal. But ONLY when I tried to update/restore it it started to behave strange/buggy and stuck in DFU mode.
Can anyone help me? :(
Thanks in Advance
좋은 질문 입니까?
