주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
Black screen, backlight problem?
I recently dropped my iphone 6 in the sink briefly. It was water damaged as the LCI shows red. I can still charge it; see it in iTune; and if I shine a flashlight on it, I can see the display, but the screen appears black without light.
Does it mean backlight fuse is burned? If so, I don't think I can do it without some real fine tools and micro scope. How much would it cost for the repair shop to fix it?
Thanks.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 12
댓글 1개
Thanks for the answers. The reason why I suspect it being the backlight problem is that I can still see it clearly with a flashlight, and I can gesture and all the things. I thought if there's an LCD issue, I won't even see that.
댓글 달기
답변 4개
가장 유용한 답변
Could just be the LCD. Clean the logic board and try another LCD
이 답변이 도움이 되었나요?
점수 1
댓글 달기
If the screen looks very dark but you can see the screen while using a flashlight or looking really closely its more than likely a backlight coil on the logic board so a new LCD/screen wouldn’t fix it. You’d have to take it to a repair shop that specializes in microsoldering and board level repair
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I would try another screen. I would rule that out before venturing into the backlight repair. Also, look at the connector when you take it apart.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
So I could be wrong . But it will be easier if you join fellow detailed pictures . If they are filters that will have a different color .
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Joe Zhao 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 10
전체 시간: 28,675
