주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 5.5” 스크린 iPhone은 iPhone 6의 큰 버전입니다.
1525 질문 전체 보기
질문 마감됨
screen flickering, ghost touches, even after replacement
hello
i dropped my phone, not from to high, but actually white bar flickering and ghost touches happend.
brought it to the apple store, the analiysed the phone and could not reproduce it, and said even if an error would be found, i am out of warranty because of too many scratches in the metal body (from keys in pocket and so on).
ok got it back, and still flickers and ghost touches like !&&*.
so i orderd a replacement screen, swapped screens, and see there, still flickers.
after digging through ifixit, i found a the problem, the flex cables seem to be not fit perfect, so i bent the shield metal above the cables a bit, and this fixed it, ALMOST!
sometimes randomly it flickes for a short time, alot better than in the beginning!
i would like to put some "buffer" inbetween the plugins and the shield, what material would fit - i am a bit scared about the heat and so on? (so the pressure on the plugins is constant)
regards
helmut
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Im having the same problem, any suggestions out there?
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
If u guys found a solution please let me know. I found that heating the connectors helps. But when I woke up the next day it was back to normal. Flickering like crazy and I can't even use it.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 648
