주요 콘텐츠로 건너뛰기
Launched in spring of 2014, the OnePlus One packs a 5.5" display and runs the Android-based CyanogenMod 12S operating system. Model "ONE A0001."
110 질문 전체 보기
Where is the screen connector located?
Hello,
I recently replaced my Oneplus One battery, my phone now completely works but the screen does not, it is always eitheir OFF or only display black. I might have messed with the screen connector but I don't know wich one it is so if anyone could tell me so that I can reopen the phone in order to reconnect/clean the connector :)
Thank you !
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개:
Florent did you fix the screen issue? I had similar issues. Dead battery first so I opened the OPO and disconnected the battery connection and plugged it in again. Surprisingly this worked. But a few minutes later my screen went black ans sinc then it stayed black.. Everything works except that my screen is always black. If you can help me out please let me know!
luyten.mathieu@gmail.com
댓글 달기
답변 3개
Florent did you fix the screen issue? I had similar issues. Dead battery first so I opened the OPO and disconnected the battery connection and plugged it in again. Surprisingly this worked. But a few minutes later my screen went black ans sinc then it stayed black.. Everything works except that my screen is always black. If you can help me out please let me know! luyten.mathieu@gmail.com
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
soft drop screen is on but hap tics touch will not respond. who fixes these? must be connection problem
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Screen connection is on top by the camera. F.Y.I if you didn't touch the screen connection then it's not the issue..
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Florent Noel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 4
30일 전: 5
전체 시간: 307
