주요 콘텐츠로 건너뛰기
2009년 6월 출시 / 2.53 GHz Core 2 Duo 프로세서
170 질문 전체 보기
Where is the airport and airport antenna?
I need to do an entire tear apart due to oil getting into my laptop. Currently, outside of the display being somewhat messed up, everything works but the airport comes and goes. I wanted to clean it off but I can't find it. It is not in the upper lefthand corner as shown in your fix it manual. Note I only have one fan. Also, where is the antenna? Could that affect the fluctuation in function?
Macbook pro mid 2009 a1286
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
가장 유용한 답변
Here's the guide you need to get to the airport card.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
like I said, there is no airport card in the upper left hand corner (above my dvd) of my laptop as show by the fixit manual you referred me to. this is the problem. It is odd that mine is different this way, I guess apple keeps changing things. I purchased my laptop at the end of Nov 2009. Is there a "late 2009, model 1286, 250 gig hard drive, 2.53 G"? Thanks
댓글 달기
Found it and verified it with apple. It is in the black hinge area and display.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Angel 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 3,967
