iPhone 5c Not Charging, After Replacing Battery & Charging Port
When I plug it in, it shows the empty battery symbol so it's detecting that it's plugged in but it's not charging.
No water damage, no screw damage.
Any ideas?
Update
Check this out
좋은 질문 입니까?
댓글 3개
Why did you replace the battery and the lightning connector to begin with? Did it charge prior to you changing those parts?
oldturkey03 의
Battery was bad and the port was bad. Prior to this it charged.
deniro444 의
did you check if is there continuity from + to - pins?
raul 의
