주요 콘텐츠로 건너뛰기
2015년 3월에 발표, 2015년 4월 10일에 출시된 Galaxy S6 Edge는 Samsung의 최신 주력 스마트폰 곡선형-스크린 버전입니다.
237 질문 전체 보기
Can I get samsung s6 edge to come out of ODIN MODE?
My phone will not switch on. I have tried to press the volume up + power + home key and also volume down + power + home key. My phone only goes to a blue page which says 'warning.. A customised os can corrupt your phone etc...' and 'press up to download' or 'down key to cancel and restart phone'. When I press down key my phone does not restart, just turns off and will not power back up. If I press the volume up key it will turn to a page saying downloading and will stay stuck on this page for hours. I have tried a number of combinations but nothing has worked. I cannot plug into a computer or go into samsung as I am on vacation on an island. I also cannot pull the battery out as I have a s6 edge and if I do unscrew it will void my warranty. Can anyone please help?
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 24
댓글 12개
after hard reset my device goes into odin mode and restart what i do
I press down key my phone does not restart, just turns off and will not power back up. If I press the volume up key .
My phone will not switch on. I have tried to press the volume up + power + home key and also volume down + power + home key. My phone only goes to a blue page which says 'warning.. A customised os can corrupt your phone etc...' and 'press up to download' or 'down key to cancel and restart phone'. When I press down key my phone does not restart, just turns off and will not power back up. If I press the volume up key .
whay if i disable usb seeting on my phone then also the reset factory and the laucher of the phone and its system UI shut down automatically ..how can i fix this please help me.. :(
maybe my chace is on with ODIN mode but don't how .. please help me lol
댓글 7개 더보기
댓글 달기
답변 12개
선택된 답변
Press all buttons at the same time and hold them.
해당 답변은 도움이 되었습니까?
점수 154
댓글 58개:
Thank you mine was stuck in this mode and I'm fairly new to the android world and this saved my butt majorly!!!
love you brother thanx a ton
Wow thanks man
thanks man, saved me
worked for me nice one dude
댓글 53개 더보기
댓글 달기
Just hold all the Buttons on the same time power button volume up volume down and home button
해당 답변은 도움이 되었습니까?
점수 22
댓글 1개:
my power button is stuck and doesn't work
댓글 달기
get into download mode then hold volume down, power home and the phone should power off. If it won't power back on try holding power and volume down for like 20 sec, it may boot normally.
Boot into recovery power volume up and home and try clearing cache partition (wont delete your files)
then in recovery try factory date reset (will delete your files)
finally if all else fails flash the stock rom (make sure same version or newer than you are using can't go back) using odin
해당 답변은 도움이 되었습니까?
점수 10
댓글 2개:
THANK YOU SOO MUCH BUDDY !!
You saved my device ! i was worried BADLY ! I was trying to install new firmware on my android ;/ thanks anyways buddy :) God Bless you :)
vol up+vol down+power+home not work for me, power+home also not and if i go to vol up or down+home+power phone goes to Odin mode, i need to factory reset coz i forgot lock pattern. please help if possible.
댓글 달기
Hold Power + Home 15 seconds (Hard reset)
Hold Voume Up + Power + Home until recovery boots.
If this doesn't boot recovery mode and your phone is stock and untouched take it back to Samsung.
If you've flashed CFW/repaired it you're going to have to put it into download mode (like you were stuck on) and flash OFW via Odin.,
해당 답변은 도움이 되었습니까?
점수 6
댓글 1개:
You are like God for me you saved me from my parents as I do this is mistake
댓글 달기
Thanks a ton. Verified! It Works! Press all the buttons Vol up + Vol Down + Home + Power and hold them!
해당 답변은 도움이 되었습니까?
점수 6
댓글 2개:
Thank you sir
it s work. do it Valium UP and Down , home , and power key for five seconds . its work. thank god and thank you
It worked for me. Thank you so much :)
댓글 달기
https://www.youtube.com/watch?v=bii27UQY...
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
When I do all 3 it go to maintenance boot mode
댓글 달기
Try this.
Press and hold together "power button + volume up + volume down + home button" for about 1 minute and your phone will reboot to nomal.
해당 답변은 도움이 되었습니까?
점수 3
댓글 4개:
When mine reboots it is in another language. How do I change this??
Thank you sir
Its not working for me
Hi, sorry for late reply guys.
Sometimes it takes more time and need to press and hold for about 1 minute.
If this does not work then wait for your battery to drain completely or bring it to your local technician.
댓글 달기
ive got a samsug j6 can someone tell me how to fix it
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I yanked the battery out of my Note 2 when it did that. Then opened up Safe Mode by holding volume down as it powered up and removed some files that possibly were corrupt
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
I yanked the battery out of my Note 2 Then restarted my phone in Safe Mode and uninstalled some apps I downloaded from Google Play that had embedded malware and its been ok since.
can anybody help me please?
i was trying to download iodine apps for my samsung galaxy s6edge plus but i cant download it
댓글 달기
So sometime this type of situations occurred. Just Install a firmware to your phone. Flash with Odin. But it may reset your phone!!!. After you phone will work properly. Be sure a right firm to your phone. 100% guaranteed. If you have any or queries. Please email me at vineil91@gmail.com. Best of luck... :) :) :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
Hi i cant get any of the above to work?help pls
댓글 달기
I know this board is old, but I'm having this problem but none of these options work. I can get to the blue downloading screen, but when I push the button combinations on that screen it just goes black and does not boot up.
해당 답변은 도움이 되었습니까?
점수 0
댓글 3개:
So does mine do you know how to fix it?
I had to repeat the process a few times before the volume down to restart phone option brought up the black and white Galaxy S6 screen to restart. However, now it keeps looping that screen and not actually rebooting. Keep at it!
Hold the power and home button together for 15 seconds
댓글 달기
Still stuck. Tried every example that was given on this page. Took the pbone back to the Sprint store where it was originally purchased from only to find that the techs there didn't know how to fix it. So now, Im just sitting on a $800 device that won't power on.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
hajera 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 29
전체 시간: 178,633
