주요 콘텐츠로 건너뛰기
Repair Guides for HP Desktops.
355 질문 전체 보기
질문 마감됨
The power comes on, but it never boots into Windows.
I have an HP All-in-One that when turned on, starts up fine. It shows the HP logo and I can access the early bios options. System diagnostics show nothing amiss.
But, after it goes through some process (while the logo is showing), the screen goes completely dark. The power button goes into a sleep mode, and if you hit a key it comes out. But no response on screen.
The hard drive seems to be perfectly operational. The fan is operational. Power brick is fine.
HP Pavilion 23 All-in-One
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
On a hunch, I reseated the connection related to the monitor. Some loose connection was tripping it up, it works fine now.
The safe mode idea was a good suggestion though.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
you should try booting to safe mode.. this problem seem to be a Driver error..if didn't work you may try loading your operating system again....
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 2
30일 전: 3
전체 시간: 108
