Asus 52F Change monitor settins blind
Hqve only ext, pic (monitor) Changed monitor optoin by mistake
How to fix since cqnt see screen
좋은 질문 입니까?
좋은 질문 입니까?
Greetings,
First try plugging in a separate monitor to see if you can adjust the original display settings.
- Should have a HDMI or video port on the side of the unit,
- get cable that match's both the laptop and monitor's plug-in's,
- if present select the 'function' (Fn) button and normally 'F7" to swap the display to an external monitor,
From there you should be able to adjust the display settings.
Good luck,
9erRed
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 68
