주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
How to fix my frozen iPhone
My Iphone keeps freezing, I've let it run flat and then recharge it and then it worked for a couple of hours and now its frozen again. I cant restart it because my lock button doesn't work and my computer needs me to respond on my phone for it to be restarted on Itunes help me what can i do?
Also the screen doesn't respond to me tapping on it
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 2개
Hello Tara,
The only way to get out of this is to open it and disconnect the battery (as a temporary workaround). Since the power button is not working, you need to plug it in a power adapter for it to switch on. If it's still freezing then you probably have a defective Logic Board.
Hope this helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If nothing else is working you can force it into recovery mode. As your lock/power button isn't working you can use a software called Tenorshare ReiBoot that will do it. It also allows you to exit recovery mode and get your phone on again.
As it is freezing all the time it sounds like you might need to do a restore as something may be corrupt. Just back everything up and then restore it back on your phone.
If it is still freezing after that you might have to just try restoring it and setting it up as new.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Tara Lieschke 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 2
전체 시간: 218
