주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Tried to replace battery, ripped glass screen off front panel
Not really sure what to do from here. Followed the battery replacement guide, instead of pulling up the whole front panel, the suction cup ripped the actual screen off the front panel. Phone still works, just screen isn't secure. Do I glue the screen back onto the phone with super glue and then try again? Google returns nothing for a problem like this, so it must be a rare occurrence. Any help is greatly appreciated
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 3개
선택된 답변
Unibond is a very good glue I've used to secure loose frames in the past, extremely strong and very easy to work with.
I used to use the iSlack on the 5S, but don't do it anymore, especially if the screen has been replaced before, because if the glass pops out and pulls the home button with it, then no more Touch ID, using something like a iSesamo tool is perfect and a lot safer to remove screens.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
I usually use epoxy when this happens, super glue should work too. Remove the front housing by prying up the frame, be weary of the cables. then remove all the parts attached to the screen (camera, speaker etc..) and do the sticky work. Give it some time to dry.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
super glue will work but is far less than ideal. Over time super glue does not stay bonded to glass well. The loctite gel super glue is a favorite of people that do this often, it stays where you put it better and gives you a little bit of working time before it cures. Don't let super glue (or whatever glue you use) get on the backlight or the edges of the lcd.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
rtja 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 120
