주요 콘텐츠로 건너뛰기
The Kenmore 90 Series is a washing machine manufactured by Kenmore.
266 질문 전체 보기
Why won't my washer drain and spin?
I replaced the washer pump, motor coupler and the door switch. It still will not go into a drain. I've tried putting it on spin to just spin the water out but that doesn't do anything. It would do it before but now it has just stopped draining at all
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 1개
stocktonelisa, does it spin?
댓글 달기
답변 1개
가장 유용한 답변
stocktonelisa, it is possible that you have a bad clutch. If the clutch does not engage, your washer won't spin. Check this guide, different model same idea. Let us know what you find.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
stocktonelisa 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 4
전체 시간: 2,203
