주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Hewlett-Packard began manufacturing personal laptop computers in 1993.
Shift key not working
I have a Hp 15 and both shift keys are not working.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 4
댓글 달기
답변 3개
가장 유용한 답변
yes my one shift key is not working
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Plug in an external keyboard, do they work now? If no, try the steps below.
Go to Control Panel then look for Ease of Access
- Click on Change how your keyboard works.
- Uncheck where it says Turn on Sticky Keys and click OK.
If this doesn't work try checking the keyboard language if set correctly.
- Go back to Control Panel then look for Region and Language and make sure all tabs at set to the United States.
- Click Apply when a change is made then try your keyboard again.
If these tricks don't work, you will need to replace the keyboard.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
only one of mine isnt help/ see it does this when i do question /
nope, doesn't work at all
댓글 달기
I put up with this for a while, using caps lock. Then got fed up so proved that it wasn’t Windows by booting Linux, just the same on there, so decided to get a new keyboard. Opened the laptop to check the part number of the keyboard. I then thought what about the connector. So I removed the ribbon cable gave it a clean brushed out the socket it went into and put it back together.
It now works perfectly!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dvidal69 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 16
전체 시간: 14,042
