Hard drive swap for smaller size
I have a 1 TB drive that is failing in my iMac. Can I replace it with a used, but working 500 GB hard drive from my old PC? Will I run into any compatibility issues? I'm trying to save money.
좋은 질문 입니까?
좋은 질문 입니까?
Unlike older models which either had an external thermal sensor glued on or leveraged the HD's makers manufactures diagnostic sensor they had started to put inside the drives. Apple contracted them to modify the drives so the sensor could be accessed via the SATA connection.
This makes it harder to put in just any drive as you need to replace the missing sensor externally. Here is a special adapter cable you'll need: OWC In-line Digital Thermal Sensor for iMac 2011 Hard Drive Upgrade if you use a drive that does not have the correct firmware.
For a few dollars more I would recommend going with a SSHD hybrid drive or if you can do it put in a second drive which in this case would be a SSD as well as replace your current HD with a standard HD. That way you can create a Fusion drive set gaining more performance.
Here's the IFIXIT guide to replace your current HD: iMac Intel 27" EMC 2429 Hard Drive Replacement
And here is the dual drive IFIXIT guide if you decide to take it up a notch: Installing iMac Intel 27" EMC 2429 Dual Hard Drive Kit. Remember here we are putting in a SSD here.
안내서
난이도:
운영
20 - 30 minutes
안내서
난이도:
어려움
1 - 3 hours
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 80
댓글 1개
Need more info on what the other drive is exactly. Frankly, HD's are so cheap now ($120 US for a 1TB drive) I don't think its worth putting in a used drive in.
Dan 의
