iPhone wont turn on after screen replacement
I have an iPhone 5 that wasn't in use for a few times thanks to the battery being drained in about 30 minutes after a 100% charge and a broken screen. So here is the problem, I replaced the battery and put it to charge so it started making a charging noise all the time. After reading the forum I discovered it was a screen problem. After replacing the screen the iPhone wont give any signal of life (before changing the sceen it conected to iTunes). The battery won't even heat a little bit. Any guesses on what is the problem? Already reassembled everything a few times and tried soft and hard reset.
Update (10/28/2015)
Can anyone tell me if I burned the logic board or only burned the battery?
While the phone was connected to the charger I removed the battery, after this it wouldnt even connect to iTunes.
좋은 질문 입니까?
