The mains fuse inside the amplifier and I found R145, R170 melted
The amplifier keeps blowing the mains fuse and i found R145,R170 are melted on the pcb can you help me fix this problem?
좋은 질문 입니까?
좋은 질문 입니까?
Step 1: check output stage.
2:power supply components.
3: check board for any leaking cap’s.
해당 답변은 도움이 되었습니까?
If these are glass fuses chances are you have a output transistor or transistors that has went bad. These devices are in place to provide sound in the speakers through a chain of other components. It will need to be looked at and diagnosed by a professional tech. This is something you may not be able to do yourself for reason of LETHAL HIGH VOLTAGES and lack of equipment and or knowledge.
해당 답변은 도움이 되었습니까?
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 467
댓글 1개
teque516, post a couple images of your board with your question.
oldturkey03 의
