주요 콘텐츠로 건너뛰기
2014년 9월 19일에 출시된 이 4.7” 스크린 iPhone은 iPhone 6 Plus의 작은 버전입니다. 모델 번호 A1549, A1586 및 A1589로 식별됩니다.
4994 질문 전체 보기
Swollen battery after screen replacement
Had my screen replaced some months ago due to a crack in the glass. Battery is now swollen and phone will no longer charge or power on. I'm not sure if the battery deterioration started before or only after getting the screen replaced.
Wondering if it is likely the battery was damaged in the process of replacing the screen or if it's an unfortunate defect in the battery that was likely there from time of purchase?
Any input appreciated!
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 5개
가장 유용한 답변
No, that is highly unlikely. The only way that would happen is if you somehow pierced the battery allowing leakage and causing it to expand. It may be from high temperatures from excessive use while charging or something like that.
해당 답변은 도움이 되었습니까?
점수 4
댓글 1개:
Thanks. I don't think I really used it while charging and definitely didn't overcharge it. Never used any accessories other than what came in the box with it either so figured it was a fault with the battery from purchase. Now to convince the retailer of that...
댓글 달기
Doesnot necessarily have to be pierced for the battery to be swollen. infact if your phone is More than 18 months old then most likey the battery gave up. Just change the battery and you will be fine.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Phone was only about 6months old when this started so I'm hoping to get it repaired/replaced by the retailer if it's a case that it was faulty when I bought it. Hard to prove I guess.
댓글 달기
Its much more likely the charging system was damaged at the same time the drop occurred that cracked your screen.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Is there any way to check for that?
I actually had the exact same problem actually that's what probably cracked your screen because I noticed a blue discoloration dot on every white page I went to on my iPhone so what happened was the battery was pushing up on the display so I went into Apple they told me about the battery and swap my iPhone 6S out with a brand new iPhone 6S so yes you're theory is probably right it happened at the purchase and the guy who replaced the screen just failed to tell you about the battery
댓글 달기
I had the same problem, changed the scream on my phone. Two weeks later battery swole up. I took my phone to Apple Store, they replaced my phone under warranty.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Can a swollen Battery cause the touch on the phone to become non-Functional.
I replaced my iPhone 6+ screen with a new one. However, the issue remains. I hard reset the phone it will work for a couple seconds then everything freezes up. Is that the battery or the Logic board.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Gof 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 18
전체 시간: 12,413
