주요 콘텐츠로 건너뛰기
처리 속도가 빨라진 iPhone 3G 개선 버전. 이 기기의 수리는 3G와 유사하며 간단한 스크루드라이버, 비집는 도구가 필요합니다. 모델 A1303 / 16GB 또는 32GB 용량 / 검정 또는 흰색 플라스틱 뒷면.
1502 질문 전체 보기
How do I remove a smashed screen with a suction cup?
I have a very smashed up front panel on my iphone 3gs and I am wondering, if I order the front panel replacement, wont I have trouble pulling the screen out in step two using the suction cup because it is so smashed up and air will get through the cracks in the smash and break the seal on the suction cup. Sorry, that was worded really awkwardly. I am sure there must be a way to do it because why else would you replace the front panel (ie. unless it was all smashed up)
Thanks
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 3개
선택된 답변
I would use clear packing tape and cover the whole screen (one piece should do it). Then use another piece of tape (making a tab) using it as the suction cup
Edited to add:
I know its an old topic but it might help others with the same issue :-)
해당 답변은 도움이 되었습니까?
점수 5
댓글 4개:
+ good thinking
+ works well
+ yup, or double-sided tape ... or, !&*!, glue something onto the front panel if you're throwing it away anyway.
Sweet! Thank you!!!
댓글 달기
i would not use the suction cup method for that - i use the small blade of my victor inox sd knife. it's small enough to use it as a lever. but you can use any pocket knive with a small blade, the best point to use it as a lever is in the middle area, near the home button.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
Thank you Markus Weiher, it worked
댓글 달기
Best tool for that is iSesamo.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
MadameBiatch 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 9,197
