이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 2개:
The airs don't use CFL's. Can you describe what you are seeing here. Is the display dim? Is part of the display not showing up? Are you able to see an image on an external display? That is if the internal is not working.
Dan 의
Can you give us the last four digits of the serial number so we can correctly identify which model you have.
Dan 의
