주요 콘텐츠로 건너뛰기
1.83, 2 또는 2.16 GHz Core Duo 프로세서
281 질문 전체 보기
GRUB or Linux / no Boot
Crunchbang Linux reason for impossibility of boot (maybe GRUB)
-Partitioniert + Reset (apple+alt+p+r) done.
-Mac OSX shows 3.6 TB Platte (instead of 500GB)
-Error messaging when trying to Disk Utilities with Mac OSX
-Crunchbang Live CD can run
-Lubuntu saysKernel Panik; Elementary OS CD shuts down; Ubuntu Live CD shuts down; Knoppix shuts down most of the time
Macbook Pro 2006 1.83Gh Intel Duo Core
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
its solved now. kept the laptop in a friends place and it fell probably! afterwards it worked normally...
댓글 달기
답변 3개
I've been able to run uBuntu 14 and uBuntu Mate on an 06 MacBook Pro A1150. Are you trying to do a dual system boot or just install Linux? Haven't tried the other versions you spoke of. With uBuntu, I used the alternate install disk and it worked just fine.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
i did install linux lubuntu (missing video driver), ubuntu (fine but sometimes slow) and crunchbang.
But the crunchbang install made it impossible to boot. Only a Live Cd of Crunchbang works now.
The MacOS X Cd shows a 3.6TB drive where a 500GB is supposed to be.
Is there maybe a different way to reset the macbook other then p+r+alt+apple?
I cant enter a bios with this macbook. Some boot parameter must have been changed, so othere live Cds of linux also dont work anymore...
http://dropcanvas.com/xr0fz/1
http://dropcanvas.com/xr0fz/2
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
If all else fails, I was able to install linux by booting the live cd in another computer, removing the harddrive from the MacBook Pro, plugging it into the first computer via a usb cable, and installing that way.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ab90 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 5
전체 시간: 619
