주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The Mazda Capella was commonly known in markets outside Japan as the Mazda 626. The Mazda 626's sixth-generation was built on the GF platform and released in 1997 for the 1998 model year.
How do I fix the door?
My passenger side door is stuck, how am I suppose to get the panel off if it's stuck?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
Can you clarify what part of the door is stuck? Was it hit and won't open? Will it not unlock? Did someone super glue the door shut?
댓글 달기
답변 1개
선택된 해법
i am a mechanic and this is one of the most tricky things to do depending on the problem. all you can do is move the seat as far out of the way as you can, get as many retainer screws as you can see out, and try to gain enough room to get your hand between the door panel and the door, and try to get on a lock rod or the door latch itself. make sure the door is unlocked even if the rod looks like it is. it takes LOTS of patience, but you can get it if you take your time. best of luck.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
amanda 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 13
지난 30일: 29
전체 시간: 2,527
