주요 콘텐츠로 건너뛰기
모델 A1502 / 2.4, 2.6 또는 2.8 GHz 듀얼-코어 Intel 프로세서 / 2013년 10월 출시
552 질문 전체 보기
Spilled tea, turned on the mbp and now the fan is loud
Hi Guys
So what happened is that I spilled a full cup of tea on my study from where it oozed all over my mbp keyboard. I instantly picked up my device and shut it down( took 5 secs at least ). Then I shock out the liquid that was still inside the mbp and placed it upside down with a keyboard over a towel. I let it be that way for half hr after which I tried to turn it up using the power button but there was absolutely no response. Then I placed it in the same setting but under 2 bulbs to give it a little heat for an hour and a half.
Now following the insanity that I have already committed I connected my mbp to the charger and it instantly started, however there were 2 complications:
1. It did not stay on without the charging cord
2. The fan was really loud and I could easily feel the rush of air from the opening on the right corner( under the screen )
When it was on it loaded to the profile section where after I typed my password, the loading bar appeared on the bottom which took forever to complete ( about a min and half .. also the mouse cursor went into the loading shape and even froze in that colourful circle shape while the computer was still loading). After that my desktop was normally displayed but the fan and the rush of air problem were still there. After that the power cord accidentally got off and the mbp shut down.
I am really worried now for turning it back on as I read we have to let it dry for days.. Can you please tell me what I should do now and if I need to open up the back cover? I might not be conveying my problem in the right manner but any good help to get me out of this safely would be priceless.
Thank you all in advance!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 1개
선택된 답변
Sadly, I think you have some deeper issues now.
You'll need take the system apart to correctly clean the rest of the tea out. It does sound like you burnt some the logic by powering the system before the tea was cleaned out.
Follow the IFIXIT guide: MacBook Pro 13" Retina Display Late 2013 Logic Board Replacement
Update (09/22/2015)
Sadly, the OS is telling you your battery is gone. So at this point you'll need to start there. Here's the IFIXIT guide to replace the upper case which also holds the battery: MacBook Pro 13" Retina Display Late 2013 Upper Case Replacement. Here's the IFIXIT part: MacBook Pro 13" Retina (Late 2013/Mid 2014) Upper Case Assembly - A-Stock / With Battery and Trackpad.
Here is a nice little program which will help you see whats happening in the SMC charging services: coconutBattery. But it likely won't tell you much more here than what you all ready know. Post a screenshot for us to see.
MacBook Pro 13" Retina (Late 2013-Mid 2014) Upper Case Assembly 이미지
상품
$149.99
MacBook Pro 13" Retina Display Late 2013 상단 케이스 이미지
안내서
MacBook Pro 13" Retina Display Late 2013 상단 케이스 교체
난이도:
어려움
1 - 3 hours
MacBook Pro 13" Retina Display Late 2013 Logic Board 이미지
안내서
난이도:
운영
1 - 2 hours
해당 답변은 도움이 되었습니까?
점수 3
댓글 2개:
Hi Dan
Thank you for your reply. Its been a couple of days since my mac was drying and I have now turned it on. It all seems to be working for now (atleast, not sure if this will bite me later) apartfrom the sticky keys. However I am still having the battery issue I reported above as in my mac is totally working off the wall charger and the battery icon is showing condition "Replace now".
Unfortunately I was unable to open the mac as I was unable to find the proper screw drivers for it, I plan to do so as soon as i get my hands on them (dont have EBay or anything where I live).
Can you help me here? Is there any tests or checking I can do without opening up the macbook? Does this seem related to the logic board or the battery?
Thanks once again for helping me out!!
You'll need at least a driver set. Here one IFIXIT store offers: 54 Bit Driver Kit. If yo can swing it go with this set: Pro Tech Toolkit as if offers most every other tool you'll likely need.
댓글 달기
귀하의 답변을 추가하세요
Macuser 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 14
전체 시간: 911
