hard reset sony ericson experia x10i
master code for sony ericson xperia x10i
좋은 질문 입니까?
Hello,
Best of my knowledge, you won't be able to find master code for Sony E X play, but you can try below steps to reset your phone to factory default.
Option 1 – Hard reset Xperia X10 using hardware buttons
1. Unlock the screen then press and hold the Power button for two seconds. Select the Power off option. If the phone won’t turn off, pull and replace the battery.
2. Hold the Left and Right buttons located under the display.
3. Press and release the Power button while continuing to hold the Left and Right buttons until instructions appear.
4. Follow the instructions on the screen.
Option 2 – Hard reset Xperia X10 using software
1. From the Home screen press Menu and select Settings, or tap the application slider and select Settings.
2. Select Privacy.
3. Tap Factory data reset.
4. Select Reset phone.
5. Select Yes to confirm the hard reset.
The Sony Ericsson Xperia X10 will then go through the process of formatting the memory. Wait for it to restart and factory default settings will be restored.
해당 답변은 도움이 되었습니까?
please resetting my Sony Ericsson x10i with the two action bottons under the sreen and power botton is not working. Please is there any other way to hard reset my device.Help me please.
Am facing the same problem how can i get your assistance
sure. how may i help you?
Guys if you are suffering over the same problem please try a technician just because i have triede several times but all the options has failed.
해당 답변은 도움이 되었습니까?
yes its true some sony not support hard reset
my phone is not support to hard reset
24 시간 전: 0
7일 전: 10
30일 전: 20
전체 시간: 31,413
댓글 4개
Hloo guys I forgot my secret answer Wat can I do pliz help me
Nsubuga Maraim 의
das funktioniert nicht
Emil Schlampp 의
Yes me be master code need
MD. Kamrul Hasan 의
me lo regalarom con átron
fernanda lujano 의
