주요 콘텐츠로 건너뛰기
The Epson WF-2540 is an all-in-one color inkjet printer. It features a 2.5-inch LCD touchscreen and four individual ink cartridges.
20 질문 전체 보기
Cannot install on windows 10
Original Post: Epson WF-2540 printer
Cannot install Epson printer WF-2540 setup will not fully install the drivers. I have this problem on both computers. Before when I had windows 8 I had no problems, I upgraded to windows 10 cannot get printer to work. What can I do?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 3개
Try running in Windows 7 compatibility mode
In compatibility mode where you see Windows 7 or 8 remove the check mark. Restart your computer then try again. Worked for me.
hi...you can also get help from this post . it helped me in getting my drivers up and running. http://driverrestore.com/how-to-download...
댓글 달기
답변 4개
선택된 해법
Boot up in Safe Mode and see if it will install. That failing,
Try the instructions here: http://www.epson.com/cgi-bin/Store/suppo...
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
The web page is no longer available.
댓글 달기
Mine works... I just used the add printer feature in windows and let it find the printer and load the drivers... No issues. Try it that way.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
hi...the link in the answer above is not working, meanwhile you can also get help from this post . it helped me in getting my drivers up and running. http://driverrestore.com/how-to-download...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Epson have drivers for Windows 10 x64 and 32 bit (among other OS)
https://www.epson.no/support?productID=1...
I have installed it and it works on Windows 10 x64 1803.
The printer otherwise is a piece of junk. scanner ADF does not accept any paper thicker then Rizzla cigarettes paper.
But most infuriating, the printer refuses to print anything unless all 4 ink cartridges are read not empty. So if I have a new black ink installed, and only want to print in B&W or greytones the printer will refuse. This is to help me.
I will never buy Epson again.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Murven Kelley 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 5
전체 시간: 13,252
