주요 콘텐츠로 건너뛰기
5세대 iPhone. 수리는 간단하며 스크루드라이버, 비집는 도구 그리고 인내가 필요합니다. GSM/CDMA / 16, 32, 또는 64 GB / 검정색 또는 흰색.
2193 질문 전체 보기
질문 마감됨
iPhone 4s battery life is only 5 hours with new battery
My battery seemed to die after 4 hours, so I replaed the battery.
Now after a full charge I still seem to get only 5 hours.
The only thing running is phone service, Facebook notications and messenger.
I did notice the phone getting warm, but not hot to abnormal.
Any suggestions on what the problem may be?
Thanks
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Where do you get the battery from? Maybe the battery has been used or it is a fake one. Suggest you choose a reliable supplier like hcqs.cc to get a original iPhone 4s battery.
해당 답변은 도움이 되었습니까?
점수 1
댓글 2개:
the first battery was an ebay battery. i thought that it could be just as bad as the old one.
the new battery is from ifixit.
no change.
Yes , the reliable supplier is very inportance
댓글 달기
It is worth buying a battery from a reputable supplier, eBay batterys can be all over the place.
But you would expect even the poor quality battery lasted longer to start with.
I would do a hard reset (DFU ) https://discussions.apple.com/thread/526...
Make sure you back up first
After restarting turn off everything that uses battery power. wi-Fi, Bluetooth. See how long the battery lasts for.
If you still having problems, probably you need to a get a repair shop to test the draw from logic board.
James :)
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
The only thing that makes it last longer now is to turn the 3G off.
Now it lasts 6 plus hours.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 148
