Hydrostatic slow in reverse craftsman 3000
No power backing up its like its not engaging
좋은 질문 입니까?
좋은 질문 입니까?
Check your belts to your pump a sloppy belt shows up in revers before forward but as it gets worse you'll notice it going forward. You may also want to check you fluid level in the hydrostatic reservoir. Hope this helps
해당 답변은 도움이 되었습니까?
Thanks the belt was loose replaced the belt that fixed the problem
I have a Craftsman Pro Series lawn tractor that was built by MTD. I started getting very low power in reverse. Forward was fine. In my case, it was air bubbles in the hydrostatic transmission. To cure, first jack up the rear axle until the wheels are off the ground. Then pull the transmission bypass rod out. Next, crank the engine and release the brake. Keep the throttle at low rpms. You will then depress the forward pedal for a few seconds and then the reverse pedal for a few seconds. Do this three or four times. Then push the transmission bypass rod back in and alternate forward and reverse several times. Shut down the engine, lower the rear axle and test. Reverse should be much stronger now.
해당 답변은 도움이 되었습니까?
24 시간 전: 8
7일 전: 57
30일 전: 231
전체 시간: 8,580
