Go + Wireless Not Powering On
HK speaker isn't powering on. I've confirmed that the power supply is outputting the required voltage (18.50). The Power board inside the unit (which has the DC, USB, and audio jack) is only outputting between .1 and 2V to the main system. The only components on this board are 4 resistors and a capacitor. If one of those goes bad would this stop the unit from working?
If it isn't one of those passives, any suggestions as to where to look to find what went bad and repair the unit?
좋은 질문 입니까?
댓글 19개
I have a similar problem to my devic turn off it self after 5 min work and did not power on until conect it to the power suply i did not what to do
saeed ghasemi 의
I got same problem. My battery died (i guess) , because when i turn on it doesn't work. Also it's not charging at all. Uhh i also holded power and + and it turned off now it turns on and after 5 seconds turns off can't even play or reset speaker. Sucks
Darkks GT 의
Same with me..no power and no charging.
oscarpaolocaluntad 의
I fixed my by changing battery to new one
Darkks GT 의
Pressing all five buttons worked for me too. So grateful for help. Had no idea how to fix it...
Erik Grind 의
댓글 14개 더보기
