주요 콘텐츠로 건너뛰기
2009년 중반기 모델 A1278 / 2.26 or 2.53 GHz Core 2 Duo 프로세서 EMC 2326
745 질문 전체 보기
질문 마감됨
How to put a key back on?
I have the Mid 2009 MacBook Pro. I spilled a little bit of juice on my keyboard, and the enter key was sticky. I watched a few youtube videos on how to remove the key for cleaning, but when I actually pulled the key off, the white hinge part came off with the key. In the videos I watched, the white hinge part always stayed on the actual keyboard. I don't know how to get the white part and the key back on now. Thank you in advance.
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
선택된 답변
The white scissor hinge will need to be carefully removed from the key and replaced back into the keyboard, and after that the key cap can be replaced. Taking time to study how it all fits together and being gentle with the parts will prevent damage to the clips.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Simply lay the key in the correct direction on the keyboard (Don't put it upside down; Upside down letters on a keyboard aren't fun)
Once the key is just laying in its socket, simply press the key down, as if you were typing. Don't push too hard though. If you hear a click, the key is back in its place.
Hope this helps.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 2,523
