주요 콘텐츠로 건너뛰기
듀얼 마이크와 802.11ac Wi-Fi 연결 기능을 갖춘 더 큰 Apple MacBook Air 노트북 입니다.
465 질문 전체 보기
질문 마감됨
MacBook does not turn on without plug in.
my Macbook air does not charge so I change it to new battery, the screen indicate the battery has 36%of power, but I still can not turn it on without plug in,
no matter how much power is remain in the battery, it turns right off , if I unplug it.
I think, the problem started with sound, This Macbook Air did not have sound for a while, and then sound came back after a while, then started this power issue, in the beginning of power issue, I charging is on and off sometime s it charges and led was on the megafacee, but it was getting worse and now no led on megaface at all and no power without plugging in. what is the solution for this???? and can I fix this problem with replacing I/O Board??
anybody give me an answer..
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개:
Was the laptop dropped recently or did it come in contact with any liquid?
댓글 달기
답변 1개
Try changing the battery.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
lillguben read the question "I change it to new battery"
댓글 달기
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 83
