How do I fix a stuck lens?
My camera lens is stuck. Is there any way I can fix this on my own?
좋은 질문 입니까?
좋은 질문 입니까?
Stuck lenses are a common problem. Usually, it's caused by sand or dirt inside the mechanism, or the lens has been dropped. Sometimes, you can't repair it yourself and you will need to take it into a repair shop. However, you can first follow the steps in this guide to see if you can fix it yourself.
해당 답변은 도움이 되었습니까?
If you r lesn has fallen and as a result is stuck, I have found on YT a totrial that can help. It has worked for me and saved me quite an expensive repair. I ahve copied teh title and link to the video below, good luck:
HOW TO Repair A DSLR Camera Lens That Is Crooked And Jammed After Being Dropped #DIY #Repair
해당 답변은 도움이 되었습니까?
24 시간 전: 4
7일 전: 23
30일 전: 156
전체 시간: 42,244
댓글 1개
I cleaned it with paper worked great
Andrew Howell 의
