How do I fix the spring for the SD card?
I have to fish the SD card out of the SD slot. I am afraid that one day it will get stuck.
좋은 질문입니까?
좋은 질문입니까?
Gently remove your SD card with a pair of tweezers to avoid further damage. When you insert the memory card, does it click into place? If not, there might be something small blocking the SD card contact. Carefully turn your camera upside down to remove any loose debris. Make sure you are using the correct memory card size for your camera.
이 답변이 도움이 되었나요?
Make sure to check inside of the SD card well there might be something soft blocking the contact point.
이 답변이 도움이 되었나요?
지난 24시간: 1
지난 7일: 6
지난 30일: 13
전체 시간: 4,850
