주요 콘텐츠로 건너뛰기
The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
133 질문 전체 보기
Tab keeps on rebooting, factory reset not working
Good day! my tablet last night was working fine, i was even able to watch a movie, but all of a sudden after i watch a movie or so, my tablet keeps on restarting every 30 secs. i tried doing factory reset through power button+volume but it doesnt seem to work after I tried it, even when i have the time to go visit settings, when i tap reset it doesnt do anything :( i even tried to delete some apps or change some settings but after it restarts, the settings and apps i change has came back :((( please help i cant lose my tab </3
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 12
댓글 9개
I have no idea what happened, but it may be possible that the charge is too low, have you tried charging it?
Hello guys I have a problem with my Samsung tablet as well just lately when I turned it off to charge for a while everything was alright until I wanted to turn my tablet on after about 30 minutes of charging...whenever I switch it on its just on that Samsung logo with its flashing stars...even after doing a factory reset there is absolutely no difference...sorry if this topic is out of this thread...any help would be much appreciated..thanks
its a Samsung galaxy tab V3 btw
I'm having the same issue. Any updates?
i got a problem with tab its use to reset and factory reset not working
Having the same problem, tablet won't stay on long enough for a factory reset. Please help
댓글 4개 더보기
댓글 달기
답변 9개
가장 유용한 답변
I am so frustrated. I finally got the Android character and says no command. Then it goes right to the page with diff steps and I picked factory reset and it completed within seconds. I actually tried quite a few others just to try and get it to work. Did a reboot or power off but same thing. It never goes past to logging in. I see the Samsung galaxy tablet S. Then it goes to next screen which is Samsung and it remains on and flashing. I can not get past it. How do I fix? Hope this can get submitted.
해당 답변은 도움이 되었습니까?
점수 1
댓글 5개:
I have been trying for weeks. Google to troubleshoot as retired and don’t want to replace. Not working and use my Samsung galaxy tab S to play games. It took me forever to get the android to pop up! Don’t know why it says no command. And the Android is laying down and there is an exclamation mark. I took pics! My tablet is fully charged. The next screen I see gives me options: reboot to boot loader, reboot system now, wipe data/factory reset, wipe cache partition, mount/system, power off. I tried all of these and still takes me back to the first two screens. Oh! At the bottom of the screen of commands it says no support single-SKU and supporter API-3. Does all this info help cause I seem to go in circles. Can someone suggest anything else?
I have exactly the same problem and can find no answers at all!
I am beginning to think these tablets are just crap, this is the second Samsung tablet to do the same thing, may have to go to another brand.
Im not able to facory reset it keeps saying that the factory reset failed
I've been trying to get in my Samsung Galaxy E8.0 Tablet and it keeps telling me that I will need the original google account email and password before I would be able to sign in or do anything else. I have no idea what the original email and password were. How do I get passed that
댓글 달기
To be honest, this sounds like malware, since the problem started after downloading or streaming a movie. IF the vid was downloaded, delete it if the device stays on long enough for you to do that. You should also delete the internet history and cache memory.
You didn't indicate if you could actually turn the tablet completely off. You have to have the device completely powered off to perform a factory reset. The fact that you've uninstalled apps and they came back tells me that the factory reset was unsuccessful or not done properly. If you've been doing this without powering the tablet completely off, that is probably the reason.
Sorry that I can't be more helpful but hopefully this will get you fixed up. ;-)
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I'm having the same problem. I'm able to turn off the tablet just in time between reboots.
I've tried the factory reset through Settings etc. (i was only succesfull doing it this way once) and tried several times, using the Power and Vol-down button. Did not change anything.
Using Wipe cache data, Wipe User data same story.
Also tried to reinstall the firmware using Odin, also not working.
Does anyone have any other suggestions I could try?
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
I have the same problem I have tried all of it and when I send it to the nearest shop to repair they say it was software problem and they say they couldn't connect to pc and then I don't know what to do pls help me solve this
The problem is maybe caused by the memory is getting full try wiping your memory and disable all the apps that are running in the background. I have the same problem with the restarting but after wiping the memory my phones stays on longer but my problem is not fix as I only have 2GB of memory.
If anyone has a permanent solution please help.
댓글 달기
Well, without knowing the particular make/model of the tablet, youmay need to search for the exact method for doing this, but... Boot into Safe Mode. This does much the same as with your PC, but prevents ALL user-installed apps from starting/running. So only default system apps are active. This is helpful in eliminating your apps/files as the source of the problem, if the problem persists. The downside is that antivirus / anti-malware can't be run in Safe Mode.
This page has details, plus pictures, of two methods for accessing Safe Mode.
http://www.ubergizmo.com/how-to/boot-and...
This is easier than me trying to tell you myself, when something with pictures can do it better. :D
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
It is probably gpu over heat try to put your tab on freezer for 5 minut if it fixethe problem just remove mother board and heat gpu slowly for 5 minut it will fixe the probleme
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
I would suggest taking it to an authorized Samsung Dealer and have them take a look at the power supply. I have a Samsung Galaxy phone with a removable battery that would restart and restart and didn't boot I did a factory reset the problem continued. I took out the battery and rubbed the contacts lightly on a piece of fabric then re-installed the battery, it worked perfect. The only issue with your tab, no access to the power supply. Good luck i hope you can get it fixed.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I have a samsung galaxy core 2 mobile. due to some problem I erased it when power it on it shows the message over and over again, unfortunately the process core android has stopped working, UI has stopped working etc when I try to reerase it by pressing the power+home+volume up the menue does not appear. each time I restart it it get starts from language selection I tried to install custom recovery and flashing but still the same problem. any solution please got crazy
댓글 달기
My tab keeps restarting, I have tried all solutions here, I completely power off my phone but factory reset has failed showing no data available. Any solutions
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
댓글 달기
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Mine is Tab 2 10.1
I've tried the factory reset through Settings etc. (i was only successful doing it this way once) and tried several times, using the Power and Vol-down button. Did not change anything.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
at sys recovery at the bottom I receive this massage : did not match sized "/system/csc common/system/media/audio/ringtones/Samsumg-Song.mp3'(no data available)
댓글 달기
귀하의 답변을 추가하세요
Jas 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 4
7일 전: 15
30일 전: 75
전체 시간: 21,607
