주요 콘텐츠로 건너뛰기
2012년 9월 12일에 발표된 여섯 번째 Apple iPhone입니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 검정색 또는 흰색으로 제공하였습니다.
2522 질문 전체 보기
Good signal but poor call audio and 3g internet speeds. Any ideas?
I have an iPhone 5, working fine except that even when the signal strength indicators show a good signal, the phone had poor audio quality on cellular calls. Also slow internet speeds. It seems that the signal is being measured as being good but in reality or somewhere down the signal line it's degraded. If anyone has any ideas I'd be really grateful to them.
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 2개
Who's your carrier?
It's giffgaff/o2.
댓글 달기
답변 2개
가장 유용한 답변
could possibly be oily finger marks inside if its had a repair? get some iso and clean down any fingerprints or residue on the motherboard and surrounding parts
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
Thanks ProTech. I used a liquid degreaser from ALDI. I hope that would have the same effect.
댓글 달기
I opened the phone last night and noticed a few things so I had a tinker and managed to solve the problem. The three things I did were to clean with a degreaser as protect suggested, the cellular antenna connections and the point at which the antenna cable connected to the motherboard; there was damage to the antenna connector furthest from the lightning port so i scraped off a millimetre of the black coating and reconnected it ensuring it was trapped under the ring and firmly screwed; I suspected that the antenna cable beneath the plate near the battery connector should have had a foam pad on top to prevent shorts with the plate so I stuck a few sq milimetres of gaffer tape onto the underside of the plate. As is usually the case with me I'm not particularly methodical so I can't say which one solved the problem but so far so good. If it returns the first thing I'll do is to renew the antenna.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
adrianlambert 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 4
30일 전: 4
전체 시간: 105
