주요 콘텐츠로 건너뛰기
First generation children’s tablet released in 2014. The Kurio Xtreme is an internet safe, Wi-Fi capable device with a motion-sensing front camera.
Why isn’t my Kurio charging?
Why is my Kurio Xtreme not charging? I plug it in to the cord which is plugged into the wall, and it still does not charge.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 달기
답변 4개
선택된 해법
The problem could be with the charging cable, the charging port, or the battery. Try using the charging cable on other devices to see if it charges them.
The problem could also be that the charging port is loose or broken, which means that you will need to replace it.
If the issue is simply that the battery level indicator is malfunctioning, resetting it may solve the problem. To do this, plug the Kurio into a power adapter, press and hold the power button until the Kurio turns off, continue to hold the power button until the battery icon shows up again, release the POWER button, and press again the POWER button again to turn the Kurio back on.
If none of these suggestions helped, the problem may be a faulty battery, which will need to be replaced. You can visit the troubleshooting page for additional assistance.
이 답변이 도움이 되었나요?
점수 3
댓글 달기
It won't cut on or charge
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
My kurio is not turning on and not chargeing
댓글 달기
My Kurio got lost a Thew days a ago give me ideas were my Kurio could be
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi... my kurio 7 stop to working..it isn't charging.. i bought it a few months ago.. its new and doesnt work.. i would like to know how i can replace it? Thank you
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
And why it stops charhing and working???
댓글 달기
답변을 추가하세요
Kyle Watkins 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 14
전체 시간: 9,177
