주요 콘텐츠로 건너뛰기
2012년 10월 23일에 출시되었습니다. Core i5 또는 Core i7 프로세서. Apple Fusion 드라이브.
Upgrade from i5 to i7 CPU
Hi,
I'm looking at purchasing a 2012 Mac Mini with an i5 processor. I have a PC at home that is not really used as I am a Mac user. The PC is pretty high spec - well it was 3 years ago. It's running an i7 processor and I was wandering if I could put it in the Mac?
Any help is appreciated.
Many thanks,
Steve
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 달기
답변 1개
선택된 해법
Unfortunately, Apple solders the CPU to the logic board, not allowing you to upgrade the processor. If you're still looking for a performance boost, though, you may want to consider adding in more RAM, perhaps up to 16 GB (it's a SODIMM DDR3 module, but some memory will not work; you may want to try Corsair Mac Memory), and installing an SSD.
이 답변이 도움이 되었나요?
점수 9
댓글 6개:
Many thanks for the througher reply Sejin.
I have the Mac Mini with I7, 16Gb RAM and 2 SSD in Raid ... works like a charm if you don’t do video editing. You can add a 2.5/5gb ethernet adapter on USB3
Why can't one unsolder the original processor and install the 7?
@penitentman - Its not that simple! Take a look at this image Logic board with Heat sink lifted Not the chips under it are BGA with out the proper gear and skills you're more likely to kill your logic board and you still need to get the BGA version of the chip which is no longer made.
Horseshit Dan. I realize not all have the skill but some do. Enough said. Never say never!
댓글 1개 더보기
댓글 달기
답변을 추가하세요
stevetrueman 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 16
지난 30일: 101
전체 시간: 32,479
