주요 콘텐츠로 건너뛰기
Apple iPhone 5s는 2013년 9월 10일에 발표되었습니다. 수리는 이전 모델과 유사하며 스크류 드라이버 및 비집는 도구가 필요합니다. GSM 또는 CDMA / 16, 32, 또는 64GB / 은색, 금색 및 스페이스 그레이.
3530 질문 전체 보기
Fluttering lcd, sometimes an issue
So, recently, I've been noticing this issue, and it's very recent for me. Sometimes when I install a display assembly, I get fluttering lines, on the lcd. This isn't the same as when you use cheap parts, and you get those white lines. It's almost a strobing/blinking light. All the colors of the lcd picture are there. But they're doing the strobe effect. It's so weird, and I'm getting really good parts. So, I'm wondering if it's something I'm doing? Could it be my magnetic mat? Which Mav ruled out, in a different thread. Anything? Anybody? Oh, I've been getting this with iPhone 5S and iPhone 6
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 2
댓글 달기
답변 1개
선택된 답변
I have seen this same issue when the LCD Assembly is replaced while the device is still powered on. Make sure you are disconnecting power before you conduct a screen replacement. Also, if your cables aren't connected correctly and you power on the screen it can cause this issue. Hope this helps! Keep us posted!
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I could see the connections not being properly seated, as the result. Thanks!
댓글 달기
귀하의 답변을 추가하세요
iMedic 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 3
30일 전: 3
전체 시간: 117
