이 토론글을 스크롤하여 댓글을 달 적절한 위치를 찾으세요. 그런 다음 "이 게시글에 댓글 달기"를 클릭하여 댓글을 이동하세요.
댓글 1개:
I was able to solve the problem by holding down the center and menu buttons for six seconds until the apple symbol appeared. Found that advice in the online manual.
This comes from a damaged AUX jack. You will have to replace it in order to remedy your symptoms. You will have to be able to solder in order to achieve this replacement but it can be done.
Nancy 의
