주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
A television game console produced by Sony Computer Entertainment, also known as PS4. First announced February 20, 2013 and released November 15, 2013.
ps4 update bootloop problem.
I bought the Playstation off cl knowing it had a problem. Keeps failing updates. Ive replaced the hdd with ssd, and installed software with several usb drives. i also tried the software its on 2.04 and every thing between current 3.00. Before I have it repaired was hoping there is a fix. I was thinking maybe pulling the cmos battery. the error code is su-30631-3. model cuh-1001a.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 6개
You have to upload the full system software not just the update
https://www.playstation.com/en-us/suppor... (scroll to the very bottom of the page)
apologies if you've already done this - but i made that mistake once
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I used the full 800mb software file of several versions.
댓글 달기
I have the same Problems. Anyone a solution?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I have similar problem since my son tried to install the update a few weeks ago. we've tried installing the full version oo and although it appered top work, a couple of days later the PS4 just keeps rebooting and saying you need to install the system software.
Will try contacting Sony support, but if anyone has any answers as to why an otherwise perfectly working machine should just fail like this following update, I'd be grateful - so will my son!
TIA
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Same problem and no solution.
Meme probleme et pas de solution de sony
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Has anyone found a solution? Same problem here:(
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Have you solved the problem? Thanks
댓글 달기
In reading online this particular error is caused by the NOR Flash being corrupted. The onle fix listed i have read is to unsolder the flash and decode the dumpfiles.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Kyle Simmons 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 3
지난 30일: 10
전체 시간: 3,699
