주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
4세대 iPhone. 수리는 간단하지만 앞면 유리와 LCD를 하나의 유닛으로 교체해야 합니다. GSM / 8, 16 또는 32GB 용량 / Model A1332 / 검정 또는 흰색.
Rear Camera Lens Cover
My rear camera lens cover is scratched. I removed the lens cover by taking off the back panel. Where can i get a replacement lens cover for the rear camera?
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 5개
선택된 해법
Hi
I would disagree. I have just replaced the rear camera lens cover on an iPhone4, by buying a replacement lens cover ( the small circular ring shape) from the internet. Cost was around £3. Fitting it was easy, but bear in mind that the original is glued in place. Also, if you get a replacement, there is a plastic film over the inside (back) of the cover, which will need removing, unless you like all your photos to have that romantic fuzzy look.
New cover is now on and a great improvement over the previous scratched cover.
이 답변이 도움이 되었나요?
점수 5
댓글 3개:
Can someone tell me where can i get the back camera lense glass? Can't find it anywhere :(
This place sells the back camera cover, see if it works for you, I'll probably be ordering it soon.
http://www.miniinthebox.com/back-camera-...
댓글 달기
After you open the phone simply use your thumbnails on the lens cover and push firmly -- the glue will give way. Be careful not to scratch the black by trying to pry it with a screwdriver.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
Yup, glued into place but replaceable - some more-so than others. Worth a shot before replace the whole back in my opinion. Changed it a couple times with just a little force and the #*% of a sharpie.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I can confirm the lens is easily popped out with minimal force from the back or inside once the back panel is removed from the phone. I don't think it was glued. I popped one out of a relatively new but broken back panel I was replacing and popped it into a used panel I had that had a more scratched lens. I just pushed out onto the bench with a spudger and then pressed the other panel onto it, so no fingerprints were put on it.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi Scott, I'd reference this answer that I wrote to a similar question.
Hope this helps!
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Where can I purchase the back that includes the lens cover?
Please read the other answer I linked in my answer here. Here's the link to it: Where to order a back panel for my iPhone 4? Unfortunately I can't give more details yet on we will have the rear panel for sale.
댓글 달기
답변을 추가하세요
scott Fata 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 9
전체 시간: 37,004
