Why does my camera say ,"No Memory Card?"
Every time I attempt to use my SD750, I get an alert saying ,"No Memory Card," even though there is a card inserted in the slot. There is nothing wrong with the card. Any suggestions? Thanks...M.
좋은 질문입니까?
좋은 질문입니까?
Guessing it's not reading the card. Try cleaning it with some isopropyl alcohol. 90 proof is usually what I use
이 답변이 도움이 되었나요?
Did you get my last response?
I guess not. All I got was that one
I tried cleaning mine, but no luck. I've tried 3 different memory cards and get the same answer. No memory card. Hmmm? Is it worth repairing or just get a new camera. My phone has just as good of megapixels. Any suggestions? Thanks
Well, did you try cleaning the contacts with 90% isopropyl alcohol, or did you just try different cards?
지난 24시간: 0
지난 7일: 1
지난 30일: 15
전체 시간: 5,218
댓글 6개
No memory card in my camera
Laura Frame 의
Use the camera to reformat the card.
Ong Ec. 의
What do you do when the camera says "No Memory Card" and does not show "format" as an option in the menu?
Richard Cannon 의
When it says no card what will you firmat bro
Francis I 의
My camera doesn't turn on guess it could be the battery, is there a way to check if battery is good.
paetme 의
댓글 1개 더보기
