주요 콘텐츠로 건너뛰기
Model A1311 / Late 2009 / 3.06 or 3.33 GHz Core 2 Duo 프로세서
310 질문 전체 보기
DVD Drive not working on iMac 21"
I started hearing my dvd drive trying to eject but there is no disk so I tried running off of dvd on startup but no it now can't read the drive the disk dosent even comeup I was trying to run disk utility but it cant repair unless it off startup disk!!
So I tried target mode and repaired it off another computer said it repaired it but no still not working !! I can hear the drive working, Im a Mac guy since day one of mac's.
I dont know what to do Next?
Help
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 1
댓글 달기
답변 4개
선택된 답변
I've never had much luck repairing optical drives. Sometimes a lens cleaning disk will work. Here's how to replace the drive: iMac Intel 21.5" EMC 2308 Optical Drive Replacement
Or just get an external that will move to your next machine. I like the LaCie USB/Firewire combo drives: http://www.lacie.com/us/products/range.h...
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
If you are under warranty, just have Apple replace it with a new one. If you are out of warranty, try the cleaning disc as @mayer suggested.
If for some reason that doesn't work, replace the optical drive.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
+ agreed
댓글 달기
가장 유용한 답변
I got new dvd drive when it stop working , have you check whit Apple : I think it was something wrong whit some of the dvd drive on the marked . It take a cd but can not read ore writ . It can work one some cd but not one adders ,like install CD . May English is bad but i tray to say that in some cases they give you new drive and install it for you .
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
Wow that s a great answer but its not under warranty :) hmm
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Marc Lappano 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 7
30일 전: 13
전체 시간: 8,642
