주요 콘텐츠로 건너뛰기
6MB 공유 L3 캐시 2.2 GHz (Turbo Boost 최대 3.4 GHz), 2.5 GHz (Turbo Boost 최대 3.7GHz) 쿼드-코어 Intel Core i7 프로세서.
773 질문 전체 보기
질문 마감됨
MacBook Pro 15" 2015 Screen Replacement
I have a Macbook Pro 15" 2015 version and I dropped my laptop and screwed up the screen, I've looked high and low for a replacement but they are in short supply. I'm curious if anyone knows if the Late 2013/2014 model screen will work with the the 2015 model.
The only one that I can find that says it is compatible is this one:
Link text
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 4개
선택된 답변
Parts for this machine are just not available yet. Your only source may be Apple. Give them a call and ask what their Flat Rate Repair charge is on it. The Flat rate may be much less than just asking them for a repair quote. Some times knowing the correct term to ask changes pricing dramatically. This failing you may be able to get it repaired. There is a company on eBay that offers Retina display service. Here's their straight sale: http://www.ebay.com/itm/LCD-Screen-Assem...
I'd check to see if this will one work on the 2015 even thought it's listed as being for the A1398, better to check before buying. They also offer a repair service. I have not used them yet so I can't vouch for them.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
가장 유용한 답변
I can tell for a fact that the other 2 models Dispay Assemblies don't work with the 2015 model. I'm having the same problem and tried both versions (2012 and 2013/2014). Although the screen fits perfectly and the connectors fit the backlight doesn't turn on.
해당 답변은 도움이 되었습니까?
점수 3
댓글 1개:
Thank you so much for this answer. We accidentally just tried 3 separate screens on our 2015 macbook pro only to realize we were installing the 2013/2014 lcd assembly and each time the screen worked but the back light wouldn't turn on. I have been banging my head against a wall. It sounds like we just ordered the wrong screen and *fingers crossed* the right screen will fix it.
댓글 달기
That's what I was afraid of - I guess I will give my local Apple repair a call. Why does Apple have to make repairing their products so difficult?
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
댓글 달기
So I ended buying this from Amazon:
http://www.amazon.com/gp/product/B015NXP...
I can confirm that it does work perfectly. The one I got did have a slight bit of light bleed but considering it was the only one I could find I can live with it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 2개:
Hello Gordon, did you end up just replacing the screen or the whole assembly? I'm looking to do a replacement and so far the signs point to replacing the whole assembly as replacing just the screen is extremely difficult? Thanks! Charles
I replaced the entire assembly as that was all I could find at the time.
댓글 달기
조회 통계:
24 시간 전: 1
7일 전: 1
30일 전: 1
전체 시간: 8,715
